will the front and back the seats from a 1989 coupe fit into a 1883 coupe gt
  • will the front and back the seats from a 1989 coupe fit into a 1883 coupe gt
    I need either one b2 coupe Quattro drivers cloth seat to make up a full set [ already have passenger front and rear ] so I can fit to a 1983 coupe gt , or ?? will a later s2 shape coupe set of front and rear seats fit ,
    The later coupe seats don't fit the old shape car, I did make a pair of fronts for my UR using just the base frame from the UR with everything else from the B4 seats.
    I should have some bits left over when I've finished rebuilding the UR but it will be a while yet..
      thanks for reply
        I fitted b4 cab front to a gt coupe by narrowing the b4 'legs' that go in the rails
        trial and error with grinder and welder. Only did it as car had no seats and I needed move it
        if doing again I'd swap to b2 bases if I had any
          Not sure about the first 1883 coupe
          ABY Cricket Green Pearl Coupe, blk leather
          THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
            But I`m sure theyll fit in this one
              Har de har
                sorry couldn't resist
