How should it look ? What is corrrect ?
  • S2_avant 19930325
    • Mar 2019
    • 648
    This is on the right side in the luggage compartment in my audi s2 avant.
    I took away the container for the wiper fluid. Under the container when i push down you can to the ground.
    Is that the way it should be ?
    This gallery has 1 photos.
    • Dec 2017
    • 6006
    No, there should be metal between you and the ground!
    • david1980
      • May 2014
      • 1027
      As above, metal underneath. The only other part in that area is some flaps on the side behind the bumper for a vent.
      • S2_avant 19930325
        • Mar 2019
        • 648
        This is the hole .. is there a plastic or rubber flap ?
          Should have part 26 both sides behind the bumper
