1991 S2 3B - Seating options and sliding backwards option.
OK, so you have the locking pins, but not the lever that sits in the U-shaped part of the pin, so assuming that you are the only driver it can be set and forget for now whilst you track down some donor seats for the handles.
Cheers n beers
Si
95 ABY S2 Coupe - Ragusa Green Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey With every option available (except a towball)
Yeah works for now. Thanks for all of your help from everyone. Good to be on this forum for a newcomer to the Audi world
I think I will get some Corbeau seats later on. For now it will work just fine. Going to change everything within suspension,bushings etc. Want it to feel like "brand new". Then interior/fix small stuff then engine.
Most likely they are not the original seats. The adjuster lever is on the opposite side 3B —-> ABY due to the shape of the tunnel. I expect someone swapped the seats and had this problem. If so you can solve it quite easily by swapping the seat bases over
