With a little remodeling without welding from S4/6 c4, of one generation.
Recaro from S3 into S2
Originally posted by kris_aleks View PostWith a little remodeling without welding from S4/6 c4, of one generation.
I may have some jacquard trim Urs4 seats available , if I get my **** into gear, to sort my original seats ....sigpic
Cab 2.3E
90q
URS6
They sit higher, as in your head will be closer to the roof. And if yoi have a sun roof, the inside of your roof is closer to your head. A not so good thing if you are tall (or even average height)
Originally posted by fish View PostThey sit higher, as in your head will be closer to the roof. And if yoi have a sun roof, the inside of your roof is closer to your head. A not so good thing if you are tall (or even average height)
I'm currently designing adpator rails to fit other types of seats
Just done one yesterday for b2, the b3 etc have slightly wider rails so Ill be making another set in the future-I want to try to use TT or similar as they're lighter than S3 ones
And if you think S3 ones are heavy you should try the Phaeton ones I took out before christmas!
- 1 like
A3 8L facelift seats would be an option. Theyre lighter and more comfortable than S3 and TT seats, 2door version are foldable and theyre available in black leather or dark gray cloth to suit B3/B4 interior. Not a direct fit though, will need adapters or some fabrication.
Originally posted by bluequattro View PostI'm currently designing adpator rails to fit other types of seats
hi, i have s3 8l recaros on my s2 coupe, they fit. height is not a problem if you adapt in the correct way. i'm 190 tall. yes they are heavy but very comfortable..
sedili recaro s2.jpgāāAttached Files
- 1 like
Originally posted by ziopinulo View Post
I am 190 cm and I have no space problems
