MB uR quattro instrument panel is dull
  • 4WDrifter
    • Nov 2012
    • 1251
    The dash in my MB quattro doesn’t seem to be bright enough. There is a knob which is supposed to control the brightness which is turned up full and I suppose it could be faulty but I was wondering if the 3 bulbs circled in the photo are responsible for the backlight?
    Then I thought I could try putting 12v across the correct terminals in the multi pin connector to see if the brightness was better but I can’t find anywhere a schematic for which terminals supply what. Can anyone help me? Thanks in advance.
    1996 S2 ABY Coupe silver
    2003 S3 8L dolphin grey
    2014 RS4 B8 prism silver
  • 4WDrifter
    • Nov 2012
    • 1251
    This gallery has 1 photos.
    • 4WDrifter
      • Nov 2012
      • 1251
      Just found these— am I correct in thinking that 12v across 2 and 21 or 22 should illuminate the dash?
      This gallery has 2 photos.
        • Dec 2017
        • 6006
        I had this issue on my last Ur. You can check the dimmer switch if you remove and use a multi meter. I did find a test thread somewhere. I will see if I can find it. My switch was fine. Unfortunately, it was something internal and Pete Knight sorted it.
          • Dec 2017
          • 6006
          This may help
          • 4WDrifter
            • Nov 2012
            • 1251
            Thanks Dave. By summer switch do you mean the rheostat knob which turns the brightness up and down?
              • Dec 2017
              • 6006
              Yes, sorry. Typo. Dimmer switch of course. My bl##dy kindle seems to love to change all my words for something random
              • 4WDrifter
                • Nov 2012
                • 1251
                Well, some good progress for me. I tested the rheostat and the readings were all over the place including infinity ohms or no current at all! It appears that the uR quattro rheostat has 2 rheostats in the switch one 0-21ohms and the other side 0-60 ohms. It took a bit of trial and error to figure out which connections were which. Then I called into Halfords and bought a tin of electrical contact cleaning spray. Squirted it into the switch, let it dry in the heat of the sun and back to the multimeter. Big difference now but I was still getting zero current in some positions. So I bit the bullet and had a go at opening the switch and I could now see how it worked and I got the sliding terminals all nice and clean. I put it all back together and the resistance changed smoothly now as I turned the knob. Plugged the dash back in and connected the rheostat and for the first time since I bought the car I now have a bright orange dash. Result.
                • 4WDrifter
                  • Nov 2012
                  • 1251
                  This is one of the corroded terminals.
                    • Dec 2017
                    • 6006
                    Nice fix
                      Excellent!
                      • sal_s2
                        • 1291
                        On a similar note, does anyone know where to get the 3 bulbs from for the illumination? NLA from audi
                          Hi Sal
                          You could ask Pete Knight, I would imagine he can source them, PM if you need contact details.
                          • sal_s2
                            • 1291
                            Yes John, can you pm me the details please?
                              PM sent
