proper removal of air bag steering wheel
  • Volkcar
    • Oct 2006
    • 86
    what do i need to disconnect on the column to not get a face full of airbag, and after that....?
    i already disconnected the battery and waited an hour
  • Knight Rider S4
    • 3541
    Battery should be enough and wear a crash helmet while doing the job
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • Volkcar
      • Oct 2006
      • 86
      so does the front part just pull off with a tug
      • Knight Rider S4
        • 3541
        What steering wheel do you have ?
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • quattronutter
          • Jan 2005
          • 690
          2 allen bols at rear of wheel,then its plain sailing,dont forget your helmet though
          • Volkcar
            • Oct 2006
            • 86
            it's a four spoke. first i thought you were kidding about the helmet, im now thinking it is a good idea
            • lini
              • May 2007
              • 159
              • Country: Slovenia
              The helmet is a *******, you need like 1Amp for a 20mS, to activate the airbag. If it would be that dangerous, nobody vould do the miming job. Disconect the batery to avoid the error for a airbag system, disconect it and dont vorry about it. The static electricity doesnt produce enough heat to start the detonation. Dont tuch the pins on the airbag, just put it away. Nothing will happen. You dont need to wait for an hour that is *******.
              S2+AAN in progress (again), BMW 3 compact
              • Jas11n
                • 5067
                My car had a recall to Audi (along with all other S2/RS2 1995/1996 80, A4, A6 & A8 in the uk) to fit an earth lead to the airbag to stop it being set off by static "after" switching the engine off and exiting the car.
                >>>> VOSA Link
                Oh, I have had an Audi airbag go off in my face. It wasn't funny and it hurt like HELL. I wasn't removing it or anything like that, rather it did it's job and stopped the steering wheel becoming part of my face.
                My advice, be as careful as you possibly can.
                2001 Avus Silver B5 RS4.
                1995 S2 Coupe - sold (sniff)
                • Pembo
                  • Aug 2004
                  • 295
                  Have you seen this?
                  I filmed this quite some time ago and it still malkes me jump.
                  Pembo
                  quattro - Original 4WD rallying
                  Rally Car photos
                  • DarrenM
                    • Aug 2007
                    • 1227
                    what you replacing it with, i've got a crap 4 spk airbag wheel on mine and was thinking of changing it?
                    • Matt_D
                      • Dec 2004
                      • 515
                      I have not taken the airbag off a S2 but did on a mates seat ibiza, i disconnected the battery waited 10 mins then touched the positive terminal (the battery clamp bit) onto the negative terminal of the battery this should drain any excess power out of capacitors etc
                      Did'nt go off for me and i did'nt need a helmet
                      '95 ABY Avant - Sold
                      '98 B5 S4 -MRC400+ = 464ps 741nm
                        They do go off with quite a bang... as this fireman found out --->
