Ilumination of instrument (Block rear differential)
there are two different types. Mine has bulbs soldered to a little PCB while other just unplug the bulbs and fit new ones.
just have to unscrew nut under rear ashtray
and pop plastic bit behind gear lever and infront of handbrake lift up and the diff lock swich is accessible.
I also had a strange experience with my diff lock button, when i push it my car doesn`t run anymore and the ABS AUS sign is lighting up. The same when i turn my ABS off, the car simply turns off
I guess the owner before me didn`t know that much about electrics also cos of the mess of stereocables i ripped out of it since my project with jeffer.
Does anybody knows something about the enginecutoff ? maybe cos of shortcircuit ?
It`s a strange thing for sure, and yes it has an abs cancel switch but hopefully i`ll find it out in the comming days, my s2 looks like a strange thingy right now totally ripped appart.
Another problem...
In my intrumens, the light of external temperatur and right turn indicator is not working... How can I fix it???
Thanks,
Hi Raphael,
There are small bulbs which twist out from the back of the instrument panel. Swap the indicater bulbs around and see if the fault moves with the suspect bulb.
The bulbs are available from the dealers or maybe go to a scrapyard and get a handful from an Audi 80.
