Recaro Subframes
  • terrybullwon
    replied
    Modified OEM bases
    replied
    Looks like Wiechers Sport do frames for the typ89, B4 etc.
  • re2500
    replied
    Suh..weeeet
    Good job andy, defo worth bearing in mind!
    replied
    Right, got a pair of mk.3 Golf subframes to try and test fit of the driver's side one shows that it fits just fine looks to be about 10mm higher but Recaro also do a reduced height mk.3 subframe. All good since the coupe/80/90 subframe went NLA!
    replied
    There are some Golf mk.3 subframes for lower seat position, they have the front bar cut and welded lower.
  • anton
    replied
    Originally posted by stiglet
    Mine are just low enough, not sure if they would be ok with a Corbeau seat and Anthony's freakishly disproportionate body.
    Its true...may just buy a couple of Corbeau seats and get a frame welded up.
    Ant
  • stiglet
    replied
    Worth a try though.
    replied
    If you get some frames made like Stiggy's then you can custom sort the hole spacings. The Corbeau Forza are damned good seats for the money, more for harnesses than 3 points tho IMO.
  • anton
    replied
    problem is that Corbeau seats come up all the time on ebay at under £100 a pair, my mate has some in his golf and i think there spot on...dont see the point in the higher price tag of the speeds, not for me at least. i'll have to take his and alex's seats out one day and compare them.....
    Ant
    replied
    You could adapt it but no point. Get some Recaro Speeds out of a Mitsy and some subframes, job done.
  • anton
    replied
    may be a daft question, but can Corbeau/cobra ext seats fit on recaro subframes?? seems that recaro are the only ones that sit low but dont like the idea of spending mega amount of cash on a recaro seat....
    Ant
    replied
    Ebay.de seems to have thrown up 1 of each subframe that I'm after to try, now to try and get a response for sending them over here...
    replied
    Looks lik eit's time to get one of these then...
  • shark_90
    replied
    By the way, mine's the Avant of course.
  • shark_90
    replied
    The Corbeau subframes in my car say "Golf III" on them. They are very high but I don't know if that's because they're Golf ones but they do fit.
