How To... Remove the dashboard
This is a sticky topic.
    Please find this comprehensive guide to this joyful task in the following link... it is honestly not as bad as I thought initially.
    Any comments welcome to improve it further.
    Good work Paul! What is the level of sound deadening on the dash itself and underneath it? :mischeif:
      making sure you park up somewhere you can open both doors fully really helps
      how come you've got V6 instrument sin there Paul?
      Rusty: not a huge amount really, some of the felt stuff and a few bits of the adhesive pads
      • dest
        • 4287
        Very little on the actual dash IIRC
        • lind4hl
          • Jul 2008
          • 2465
          Can you get Passenger airbag out without removing the dash?
          • Foeglass
            • Apr 2009
            • 68
            If i remember correctly, you have to remove the glovebox, and than you will see one torx bolt,
            undo the bolt (it's a long one) and than you should be albe to pull the airbagunit out.
            Take note that there are 2 plugs in the back of the airbag that need to be unplugged carefully.
            "95 Audi S2 Coupé
            "02 Audi A8 6.0L W12 Quattro
            "01 Audi A8L 6.0L W12 Quattro
            "94 Audi Cabriolet 2.8 (in bits 'n pieces)
              if you have cruise control, the ECU will be screwed to the dash behind the glove box - needs unplugging before dash can come out
                Safe init, ta.
                  Didn't take enough photos as I went on the S2... Had to nip out and take some snaps off the V6 dash to complete the guide.
                  Good point on the doors actually.
                    Also a good point there... should really add that to the guide. If anyone has pics of that and any other photos of how/where the airbags connect that would be good also.
                      i'll try and get a pic of the CC module under the dash later if i remember
                      • johne
                        • Apr 2007
                        • 1406
                        Also take the chance to replace/upgrade the front loudspeakers in the dash whilst it's easier with the dash out.
                        John
                          They'd be easy enough with dash in place unless going up from 10cm diameter - but yes its worth a thought.
                          Next step for me is to try and identify a lot more of the dreaded wiring plugs on the loom under there and associate them with the schematics - oh joy !
                          • adamw
                            • Dec 2005
                            • 348
                            • Country: Shetland Islands
                            disconect the battery to be on the safe side. especially if it has airbags fitted
                            cheeRS adam
                            RS2+
                              Airbags have a reserve battery, but yes I should add a disclaimer about this for airbag models in case they are especially sensitive.
