Coupe Carpet Removal / Roll Cages
    Nearly there with the carpet removal on the S2, only problem that remains is the front section that people cut. Run out of go to get it finished but glad I started, the sound deadening is like a sponge, absolutely soaked through on both sides, front and rear
    Are there any BTDTs on carpet removal, just the last bit to get sorted...
  • K Simmonds
    • Dec 2007
    • 7632
    It's a right fecker, without removing the dash and heater-box, it can however be done if you remove the bottom bits of ducting off the heater box then get really angry with it.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
      Right, thought that might be the case The rest was pretty much out anyway, just had to remove the lower section of the centre console, all done now. I've removed all the ducting that you describe and can't see any thing else holding it in other than a bit of friction. Will see if I can get a helper for that bit I think...
        All gone! Horrible sodden sound deadening out now too, just got to tidy it up tomorrow and get all the cables tied up out the way, will get most of the plastic trim back in to cover it up, doesn't weigh much TBH. Will leave it like that till I can get the bloomin' leaks sorted
        If it stays like this then I'll get a foot plate made up to the correct dimensions, needs to be about 2" high to work properly.
        JAYSUS, THAT CARPET IS HEAVY!!!
          • K Simmonds
            • Dec 2007
            • 7632
            Yep, that's one heavy rug!!!! I weighed mine bone dry and it was over 15kg, their probably nearly double that wet.
            1994 MTM RS2.
            2000 B5 TQS.
            • dest
              • 4287
              When I replaced mine with a black one I didnt bother trying to get it back under the heater etc, just a straight cut across (front to back of car) on the bit that "goes round the back" and then it could be just tucked in on either side.
              Once its all back together you cannot see that its been done atall
                Yeah, that's the plan if it doesn't fall back together. Then again, it'll be like the spare wheel, I'll get used to having less weight and then it'll take permanent residence in the 'spares cupboard'
                It just keeps heading towards a track car, just got to get myself up to track driving again now...
                  Andy if your ABY carpet is in good nick flog it and i've got a gnarly 3B one that half the backing is coming off you can have (shave about 10kgs off it like Kit is doing
                    I'll be keeping the carpet, like everything else that's come out, it can go back in if use changes or I sell up.
                    Tar removal next, then a cage
                    • rj scotty
                      • May 2006
                      • 2195
                      The worst job I have done on a car, Tar removal from the mk1.
                      Good luck
                      BUT I DON'T WANT A NEW CAR!
                      1995 S2 Avant, Volcano Black
                        No carpet and a pair of Recaro Speeds make Rusty a happy boy
                        • s2driveruk
                          • 12696
                          welcome to my car there Andy Does weigh a ton though but makes a nice change to the exhaust note once its out, you can hear much more
                          1992 3b S2 Coupe
                            I want a cage and some 3" harnesses now, a nice blue set to match the Recaro stitching
                            • andy10v
                              • 5996
                              Full cage?
                              Sold ABY-stock
