The 5 bolts which hold the door glass window frame in place, should have thin and thick u shaped plates behind them, Does anyone have any pic's, diagrams or info on which ones go where ?
Cheers Jon.
Cheers Jon.
After some fiddling with the front wing adjustment and door adjustment, the shut lines are now even and the door shuts with ease, also tested for leaks with a hose and all is dry inside.
