A4 SPORT Steering wheel to 90Q
  • hermanio
    • Jan 2009
    • 805
    oke, thanks for your help. so i need another black/violet connector, or the whole loom? is it plug and play ?
    5 Cylinder Freak
    • cd_contact
      • Jan 2010
      • 19
      • Country: Romania
      Just the connector, you will have to remove the wires from your old one and plug them into the new one. Or if you get the connector from the A4 you can cut it with ~10-15cm of wires and solder your wires onto these. After that it's plug and play. The wire colours should be the same ... so you don't need help identifying which wire goes where if you get the connectors with wires from the A4 . Good luck
      • hermanio
        • Jan 2009
        • 805
        thanks ! i will take some pics when ive got it in..
        5 Cylinder Freak
        • Ruffiano
          • Sep 2007
          • 1458
          I recently swapped an a4 sport wheel on my coupe, it fits the spline (as it is an "early" sport wheel), the only part that didn't fit was the column surround and the cancelling part of the clockspring. State side many urs4 owners swap on thw later s6 style three spoke wheel and have the same problem we face, I followed this guide to "modify my canceling ring", now most of the guide doesn't apply except how to modify the canceling ring, following this method there is no need to change your stalks.
          http://s-cars.org/postnuke/downloads...Conversion.pdf
          • hermanio
            • Jan 2009
            • 805
            wow thats great !
            5 Cylinder Freak
            • hermanio
              • Jan 2009
              • 805
              i've got it in, thanks !!
              5 Cylinder Freak
              • Ruffiano
                • Sep 2007
                • 1458
                #22
                5 speed and no diff button? What car do you drive?
                Also which method did you end up using?
                • hermanio
                  • Jan 2009
                  • 805
                  i used your method, works pretty good. i drive an 80 avant 2.3 (s2 look)
                  5 Cylinder Freak
                  • Nuvo
                    • Nov 2003
                    • 3826
                    #24
                    Is it an Avant 2.3 10v? We only got the saloon, cabriolet and Coupe with this engine in the UK. I just had a peek inside your virtual garage.
                    • hermanio
                      • Jan 2009
                      • 805
                      yes avant 2.3 10v ng. i would like to have the 2.3 avant quattro but it think its never produced..
                      5 Cylinder Freak
                      • yavor20v
                        • Apr 2006
                        • 163
                        • Country: Bulgaria
                        #26
                        this is from golf 3,the red line shows where must to cut
                        on my coupe the steering wheel fit almost "plug&play" ,i had only to assamble it but mine was from A4 98'
                        • Josh-stateside
                          • 741
                          So I sat in a 1993 audi 90 quattro with an audi 1996 3 spoke steering wheel and he did it a way that no one has done it yet. He kept the stock column switches and trimmed the plastic so it would fit up. If I can get him to post a how to thread on the forum I will have him do it.
                          • thabarman
                            • 2
                            Originally posted by Sküll
                            the adapter
                            hi there i was wondering if you know how to get an 2001 s4 steering on a 1994 QCS. and if yes where can i get the parts from??+ of course $$$?
                            • thabarman
                              • 2
                              where can i buy that part?
                              and will iy work for an audi 90 1994 cs Q
                              to 2001 s4 steering wheel?
                              • Ironman80
                                • 53
                                • Country: Russian Federation
                                #30
                                Is it necessary?
                                After installing the adapter does not have enough threads for the nut. The reason is that it does not cut?
                                illustration
