My odometer has stopped working all of a sudden. It's not a big deal as the car is already at 215K but it's handy to have for judging oil changes and to see when the car will finally have made it to the moon.
All other gauges work as does the fuel computer. The trip counter has also stopped working.
There is a chance you have some dried soldered joints on the circuit board inside. I wouldnt advise opening it up unless you know what to look for. I have seen a guide on how to repair can rememmber where. I f I find it i will post a link.
Mine too.
Both on the KM and the Metre. I am not sure how long I have run the engine.....
Apparently, the consumption display is still displaying except some glitch on the LCD liquid looks like scattered on the figures. Can't see exactly how much fuel consumption I am going.
Any ideas on how to fix it, especially the Trip meter. Is it driven by wire since they are analogue...
2002 A3 8L
2005 TT 3.2 Quattro
2007 A4 Avant B7 (hers)
2009 100 C4
2009 A6 Avant (hers)
2010 RS2
2010 S2 Saloon
2011 KTM SuperDuke 990 Olive Green
Speedo failure is usually just dirty contacts. If you remove the circuit board from the clocks have a look for some pins as shown in the pic, clean them all up with some elecy contact cleaner and it should be good as new.
Hi,
I manage to open the cluster.
What are these 4 pin contacts btw? They don't seem to connect to anything.
2002 A3 8L
2005 TT 3.2 Quattro
2009 100 C4
2010 RS2
2010 S2 Saloon
Mine too.
Mate I think you need to replace it
- Looking for a S2
- Lancia Dedra HF turbo i.e. (4sale)
- Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
my speedo stopped working so took to pieces and found that the white face of the clock had peeled behind the needle so stooping it moving a quick scrape and it was sorted hope you sort it soon
