Avant headlining
  • epic
    • 1317
    Avant headlining
    How is the headlining in an Avant fixed in place?
    Apart from the handles, sunvisors A,B,C,D trims how is it fixed?
  • hermanio
    • Jan 2009
    • 805
    glued around the sunroof and glued on the back of the car just before the rear interior light, and you need to take the handles above the doors off to get it out.
    5 Cylinder Freak
    • saltinot
      • May 2004
      • 1946
      Hopefully you've got a sunroof. If not the headliner is extremely difficult to remove.
      • epic
        • 1317
        What kind of glue is used?
        No sunroof but it needs to be retrimmed!
          A heat gun will help with the glue.
          • epic
            • 1317
            Left it in place. Removed old headlining material and foam. Then Glued a new one in place. Perfect eventually. Luckily I had help as it's a 2 man job.
            • urS6Tom
              • 773
              Nice - is your new headliner OEM or a custom job?
              • epic
                • 1317
                Dark grey very similar to RS2
                • hermanio
                  • Jan 2009
                  • 805
                  nice, any pictures ?
                  5 Cylinder Freak
                  • epic
                    • 1317
                    Sure when the trim is all back in
