Hi All, Help Needed
Anyone know how to remove to boot side panel trim on passanger side, need to remove to find place for radio control box, Have got all bits off I can see and still
seems solid to me, Had a look for threads and can't seem to find anything
you need to remove the plastic trim near the rear window, carpet, fold the rear seat, remove the side foam, remove the cap of the belt, unscrew trim for the load cover (bolts hidden under the little carpet), and ti is stuck under the side window, so you have to lift it up for removing.
