Interior door cards retrimming?
  • A80Avant
    • 10873
    • Country: Greece
    Mdz: indeed great work there. I wish I had the time and patience you have!
    Where are you located by the way? Maybe you could do mine! Haha
    • europeanme
      • Oct 2005
      • 3817
      does it have to be a trimmer up your way?....somone I used to work with, her husband is a car trimmer and I've already offered the services to Brian for his shorty dash etc...
        Where about's does that guy work Mike?
        • mdz
          • Jun 2012
          • 775
          • Country: Latvia
          I'm far away - in Latvia.
          And I'm doing stuff like this mostly in summer when weather is nice because it needs to be done outside.
          • europeanme
            • Oct 2005
            • 3817
            Derby....
            • A80Avant
              • 10873
              • Country: Greece
              #21
              Doesn't have to be Mike. You could do me a favour and ask him how much it would cost to replace the trims with black alcantara? The current plan would be to get them into a pallette to Greece as I was going to have some stuff shipped anyway and I have a guy there who would do it for me while the car is at Brian's.
              If it can be done in the UK of course it saves the hassle
              • @ndy
                • Sep 2012
                • 205
                How did you bond the 2 together again? Glue or screws?
                Surely 'bond' implies glue?
                • A80Avant
                  • 10873
                  • Country: Greece
                  #23
                  Yes. I thought that as well. Just making sure as one of the guys here suggested screws on various places that they have done before
                  • JP
                    • 1858
                    Used windscreen bonder. Goes of quick and is never coming of again
                    UrS6 Stroker + HTA3586 =
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #25
                      I see. This came up as an option as well. Good to know
                      Thanks for the answers
                      • jade
                        • Jan 2005
                        • 1811
                        • Home: New Zealand Current: Spain
                        #26
                        I am looking at mine also, I had 3 re done 2 years ago and now they have come un stick on the edges
                        RS 2 580HP
                        • State'd RS2 Coupe
                          • 57
                          Agree with mdz
                          I did this recently on my grey leather int. Pulled the doorcard, bent off all the pushlocks, then pulled off the leather, removed all the dead foam (messy & boring).
                          Then used waterproof multi-purpose spray glue to re-glue new foam to leathers, cut and fit edges, door pull openings, then re-glued to doorcard.
                          Biggest issue was getting the edges to look good and hold. Ended up using some speaker wire to wedge into the groove to hold while the glue set. Also use a bit thicker foam than OEM to ensure you don't get a loose re-fit.
                          Can't imagine any decent shop would have an issue doing this if I could.
                          1990 Coupe Quattro, Full RS2 Conversion
                          http://www.europeancarweb.com/featur...rs2/index.html
                          2008 S4 Avant, Sprint Blue
                          • epic
                            • 1317
                            If you use Silaflex / Tigerseal it's never going anywhere
                            • europeanme
                              • Oct 2005
                              • 3817
                              Vas, have you got any photos of the offending door card?.....
                              • audi rs2 1995
                                • 262
                                • Country: Denmark
                                #30
                                from my car -leather / alcantara
