Odometer not working
    Odd one, my Speedo works just fine but I noticed that my trip meter hadn't moved since the weekend and a drive today confirmed that the odometer is static also. Is there a drive that's broken or other?
  • varia
    • 821
    • Current: United States
    I had similar problems, could be the plastic gear or the cold solder joints. VSS is rarely goes bad
    • Rikki Kitto
      • Feb 2010
      • 6276
      Me too
        Unlike an early water-cooled VW or Audi, e.g. 1986 Jetta 2, there is no speedometer cable between transmission and the instrument cluster on the B3/B4 and C4 Audi S-cars. There is a G22 Vehicle Speed Sensor as discussed HERE. As a result, if the speedometer is working but the odometer is not, then there is a problem with the odometer.
        The mechanical odometers are based on electrically driven gears. One of the gears breaks, the odometer stops, just like the old mechanical speedo/odometers.
        I am quite sure I have seen a thread with photos on this forum about changing the drive gears in a mechanical odometer.
        • andy10v
          • 5996
          There is a little white plastic gear that can break.
          I think I have read that pressing the odo reset at just the wrong time when moving can break it. Also I am sure I broke one when I took the clocks apart to change the faces.
          Sold ABY-stock
            Any info on replacement?
            • andy10v
              • 5996
              Sure, how to with pictures on a 1990 CQ
              Sold ABY-stock
                Originally posted by andy10v
                Sure, how to with pictures on a 1990 CQ http://www.odometergears.com/documen...eplacement.pdf
                Blast. Beat me by 4 minutes
                • andy10v
                  • 5996
                  You are getting slow, RS2 cam timing must be melting your brain
                  Sold ABY-stock
                    That, and the sun was in my eyes.
                    • LSG
                      • May 2010
                      • 897
                      My trip meter and odometer stopped working this week. It was the trip meter button as i pushed it vigorously few times and it started again
                      • LVrainman
                        • Nov 2007
                        • 136
                        • Country: Latvia
                        maybe this thread could be of any help
                        audiScars
                          • 12431
                          Uploaded the gear replacement guide
                            Took it to bits and it was indeed this gear. Is there a UK supplier?
                              K24R billet odometer gear?
