Recaro Seat Frames
Ford Recaro seats are cheaper usually, about €150,- a pair over here. But I guess there is not much available over there.
I have a set of universal Recaro seat sliders for sale, it still requires making a frame with Golf or 80 parts though but it shouldn't be too hard.
Should also have 1 Golf 3 Recaro frame left. Can do you a package deal and send it in one go.Comment
I've found a set of B3 Audi 80 Frames..still to pick up. How much for the universal sliders?Ford Recaro seats are cheaper usually, about €150,- a pair over here. But I guess there is not much available over there.
1996 S2 ABY SilverComment
B3 Recaros frames? What ate the part numbers? The B4 ones have the option of putting the handle on either side, so you should be able to fit them. You need handles off an old seat...
Don't fit frames and sliders if you're taller than 5'6" / 160cm ... LOLCheers'en, AndyC
I only found standard B3 frames, not recaro ones, would they be ok? I am about 5'9
