door cards repair
  • robo
    • Aug 2004
    • 2086
    • Home: Poland Current: England
    door cards repair
    Hi, I am having bit of a problem with the leather on the door cards.
    It looks like all the leather is peeling away from the foam and this looks a bit untidy.
    Just wondered if there is a solution to get this back to order DIY style or should I find professional shop to do it. And do you know any in south east.
    sigpic_________
    Rob
    I've got the same problem mate.
    • Rikki Kitto
      • Feb 2010
      • 6276
      Me too😣
      • mac2226
        • Jun 2008
        • 1289
        Door card leather
        Had same problem on coupe so I changed the leather for alcantara looks better
        • _ShurikeN
          • Mar 2010
          • 733
          • Country: Russian Federation
          It's up to Your taste, but it's doable by hands, if You ask.
          This artificial leather trim was taken from another doorcard and glued with a foam:
            That looks like a nice job. How did you manage to glue it without making a mess? I was thinking putting the door card flat on a table and trying superglue.
            • Golfboy666GTI
              • Sep 2008
              • 571
              • Country: New Zealand
              Anton did a good repair on his S2 door cards here:
              Sadly, RS2 door cards arent leather.
              1980 VW Golf GTI Track Car
              1995 Audi RS2
              • _ShurikeN
                • Mar 2010
                • 733
                Used a table and special glue for foam rubber. Also put a gentle even press onto the glued "leather" through soft material.
                Glue was bought in a domestic/building supermarket. I was a little bit lucky to come across a good quality glue. Had bad experience with a glue of other brand.
                • K Simmonds
                  • Dec 2007
                  • 7632
                  I repaired mine by carefully removing all the 'leather' fabric and cleaing all the foam and crap from both it and the door card, gave both a quick wipe with thinners and stuck it back on with lashings of Tiger Seal.
                  I used some heavy speaker wire to hold the edges down, making sure there was sealant right up to the edges but not so much that it splurged out anywhere. Obviously I removed the wire once I'd left them overnight for the stuff to set.
                  It worked really well, the stuff is still stuck fast after a year.
                  1990 B3 2.0 80 quattro.
                  1992 C4 2.8 Avant quattro
                  1994 MTM RS2.
                  1998 B5 TDI quattro Sport.
                  2000 B5 TQS.
                  • Christophski
                    • 3632
                    Kit, do you think the same tecnique can be used to stick the cloth down instead of the leather???
                    • K Simmonds
                      • Dec 2007
                      • 7632
                      Yes, though you'd have to be a bit more cafeful with the amount of Tiger Seal you use as cloth is obviously more pourous. Idealy do a test on an old bit of cloth and a simalar plastic surface.
                      You may find this product works better with cloth,
                      http://www.ebay.co.uk/itm/Everbuild-...item233450827b
                      1994 MTM RS2.
                      2000 B5 TQS.
                      • Christophski
                        • 3632
                        Cool cheers bud. Will order some and give it a go
                        • robo
                          • Aug 2004
                          • 2086
                          Sorry should have said is on s2 coupe.
                          sigpic_________
                          Rob
