Door Card Material
  • ianmt
    • 130
    Door Card Material
    Some of the door card material on my 3B coupe has come loose/unglued
    Is there an easy way to stick back onto what remains of the foam, or is it best to remove all?
    t
    '91 3B Coupe
  • McX
    • Sep 2014
    • 88
    Remove and use new foam with contact glue. Old foam is like a sand behind it. If the cloth or 'leather' not damaged should be able to put it back. Just done it on mine.
    • Klobsters
      • Dec 2012
      • 162
      There is nothing you can save - the foam is gone. Here is a pic of mine (It just fell of during some hot days)
      Just new foam will help.
      1994 Audi 80 Competition
      • ianmt
        • 130
        Thanks Guys Do you have any contacts for source of new foam please?
        '91 3B Coupe
        • Monkeymagic
          • Mar 2012
          • 3419
          Just visit your local trimmer they will sell you the foam cheap enough
          • McX
            • Sep 2014
            • 88
            Put this in ebay serch.... Scrim Foam 54" wide. 3mm, 6mm, 10mm, 12mm, 18mm
            I used 6mm one and contact glue they selling.
            • ianmt
              • 130
              Fantastic, thank you so much
              Regards
              '91 3B Coupe
