Some of the door card material on my 3B coupe has come loose/unglued
Is there an easy way to stick back onto what remains of the foam, or is it best to remove all?
t
Remove and use new foam with contact glue. Old foam is like a sand behind it. If the cloth or 'leather' not damaged should be able to put it back. Just done it on mine.
