How to remove sunroof interior panel
  • cadiddy
    • Nov 2012
    • 294
    Hi, Removed headlining today to retrim and sort a sunroof issue. Came to remove the sunroof interior panel but wasn't sure how it's fixed? Glue or clips? Was getting dark and couldn't see what's what there tonight.
    Thanks in advance
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    Thanks in advance
    It's on clips pull the panel towards the back of the car make sure the sunroof is on the tilt position
      Slide your fingers backwards above the panel, you'll feel two plastic spikes each side, push them apart and the panel will slide backwards
      • cadiddy
        • Nov 2012
        • 294
        Cheers guys
