i have the ADX pretty much 100% working now. With the ADX you can live trace all of the mapping to see what cells you touch given your table axis's. also you can data log directly in tuner pro and play back the allowing you to also see what cells where touched in your mapping. i still have to associate all of the logging variables with all of the maps but i have the major ones covered so far. also i have the ADX setup with inputting 0-5V AFR on ECU pin 46 for live reading straight from your wideband controller. there is no target AFR in the ADX but if someone wants to add it they can gladly do so. on the wideband input you cannot have the map switching patch enabled or it will screw with your AFR reading. i dont get the whole github thing so if anyone wants the XDF/ADX combo you can get it from my google drive, the link is below. i have the XDF and ADX in rar file so you will need winrar to unarchive them. I attached a PDF to this post explaining how to get rolling with logging in tuner pro.
I forgot to note that you must use my XDF with the ADX for live tracing to work, the official XDF in PRJ's github is not setup to interface with my ADX. if someone wanted to take the time to setup his XDF to interface with the ADX and submit it to his github that would be great.
