Simulated Narrowband into motronic
  • bmwman91
    • Dec 2017
    • 16
    Wow, so on second thought I am not picking one up on eBay. I guess I am spoiled by the fact the M1.x units can be found for ~US$50 pretty often. I will just stick to doing parallel work on the subsystems which are identical between the two units. Sorry about going off-topic...
    When trouble arises and things look bad, there is always one individual who perceives a solution and is willing to take command. Very often, that individual is crazy. - Dave Berry
    • Acki
      • Mar 2014
      • 302
      Atsome BMW forum I found something nobody meantioned yet.
      Motronic is expection a 0.1 - 0.9V signal, LC1 standard configuration is 1.1V.
      I changed this and during warm up/error I set 0.45V (Lambda 1), no DTC yet.
      • prj
        • Mar 2010
        • 6308
        The problem is not DTC, the problem is when you restart on hot engine with the gauge cold the fuel trim will run away without the patch i have in my software.
        • Acki
          • Mar 2014
          • 302
          When the Lambda signal is lambda 1 too?
          I will take a look into your patch.
          • prj
            • Mar 2010
            • 6308
            It depends how exactly "1" it is...
            A delay is all that is needed.
            • Acki
              • Mar 2014
              • 302
              Ok I see the issue, thanks! I will inspect your code and try to understand
