At first many thanks on the creator of this mod.
I have tested it and almost all is working nice.
But i have problem with boost regulation.
All the time i see only spring pressure and n75 dc is zero, target boost is only 150 kpa. In map is 270 kpa.
Please, can somebody help me.
A few options:
1. You have problem with cam-crank synchronization (belt off by 1 tooth).
2. You have mapswitching and boost failsafe patch enabled, but nothing connected to MFTS wire -> It is in safe mode. Remove the boost failsafe patch. 27C512 -> Patches -> MFTS input boost cut enabled -> Remove patch.
3. Your car is conversion from automatic and not all wires are removed or TCU is still in car.
4. You have some fault codes in ECU.
A few options:
Hi,
have checked the timing belt, is 100% on the marks,
have removed both patches from ECU,
checked fault codes, there are only two: throttle body switch and engine speed signal,
tryed the car with another moded ECU,
car has swapped engine and loom, but from manual transmissin car.
but still no boost and N75 request.
what i m dooing wrong?
Hi,
It’s not a bad MFTS signal by chance? (sorry if you’ve already covered this, I have not read everything)
Have checked the wiring from MFTS and the pin46 in JPT55 ECU connector is missing (AAN harness).
But both patches are removed.
Can be this the problem?
Please upload your current binaries here (fuel/boost) and I will have a look.
OK, re-enable the boost cut patch in tunerpro, then save the binary.
After that open with hex editor and at address 0x711C you have 50 09, replace it with with 00 00.
Then let me know if you have boost control please. And actually if you don't have anything connected to MFTS wire, just enabling the boost cut patch could also solve your problem.
If it doesn't the problem is probably somewhere else.
Sorry, have not read the second reply, IT WORK NOW!!!
THANKX!!!!!!
