S702 information
  • #16
    Ha, I am so dumb, you are right about the S_ pins. Pins 29-34 + 35-39 serve the same input switch functions on both DME's. The values that S700 reads from addresses 40h and 41h correspond to the states on those pins (plus the 6 bidirectional ones). I will play around with this more later to make sure of the mapping. It seems that writes to address 40h get output on pins 19-26, but read from pins 31-39. Reads to 41h seem to be pins 29, 30, 3, 4, 5, 6 10 & 11, and I am not entirely sure what writes to 41h are. Pins 3, 4, 5, 6, 10 & 11 change state after a write to address 20h, so either that writes to them directly, or it is some sort of port enable register. I guess I will just have to burn some small IO test programs to some spare EPROMS to force toggles on various bits so I can look for them in the output.
    When trouble arises and things look bad, there is always one individual who perceives a solution and is willing to take command. Very often, that individual is crazy. - Dave Berry
    • #17
      The thing has 3 PWM outputs as well, all can be used.
      They are labeled TV1/TV2/TV3 in the schematic.
      You have seen the schematic right?
      • #18
        Yes, I have a copy of the schematic. It looks like there are actually 4 TV# pins on the chip (0-3). The acronyms used for a lot of the things on there are difficult for me since Bosch either uses their own nomenclature, or they are acronyms for technical terms in German language, which I am not fluent in!
        Things did seem to go off on a bit of a tangent in the old thread before this new subforum was made, so I think I will probably go and spend a bit more time with the logic analyzer and in the code. I do not have nearly enough of an understanding of the ROM code to know what the commands to S702 are really doing!
        • #19
          Thanks for moving your work over here BMWman91, i was super bummed to see my thread got locked.
          "The really good drivers got the bugs on the side windows." Walter Röhrl
          • #20
            Actually, it looks like PRJ and the mod team did it. I went to check your old thread and thought that the stuff I had posted was deleted or something! On the one hand it is a bummer that it was locked, but it looks like there is even better news since there is a whole subforum dedicated to the super cool efforts people are working on!
            • #21
              Yes, I moved everything regarding the S702 into this thread.
              It is a horrible practice to start long threads talking about multiple things because it is impossible to track/go through it later.
              • #22
                Hi I am still trying to understand how the s702 and its output are managed by s700 like injectors and evaporations solenoid. Can someone explain a bit or name some address in xram what are they.
                Here the info I have : p1.7, p4.0 and p4.6 seems to be related to injection cause they are connected to s750 chip that actually holds the last bits of lines to injector before it goes onto boost board.
                as far as XRAM these upper XRAM are accessed in routines that use ports above : 0xA081, 0xA010, 0xA011, 0xA040, 0xA041, A009, A021, A020, A002, A003, A004, A005 A008
                I know A040 and A041 are used for idle switch, AC and compressor and some auto trans switch and feed RAM_20 and RAM_21, is this true?
                But, I cannot figure how the PWM output are used like evap. How does s700 gives a PWM value to it for s702.
                Any info or confirmation of what is/are the xram above o I can continue my understanding?
                Thanks
                • #23
                  Yes A040 is related to the AC switch but I have to work a little bit more on this point too.
                  PWM signals seems to be generated extra.
                  • #24
                    At the moment I know 2 Versions of the CC 151 V1, 30240 (at V8) and 30074 (at 20V) - but I don't know what's the difference of course.
