TCU Communication
  • prj
    • Mar 2010
    • 6308
    You are trying to control AT with standalone ECU, but this is hard to get working.
    Because you need an ECU that has a notion/understanding of torque, and ability to give the torque that the gearbox requests.
    WIth a cable throttle you need heavy timing retard and fuel enrichment to prevent high EGT, and also it needs to be progressive.
    • ChrisAudi80
      • Oct 2011
      • 236
      • Home: Norway Current: Thailand
      #32
      [QUOTE=prj;n2017780]You are trying to control AT with standalone ECU, but this is hard to get working.
      '96 UrS6 auto PRJ chipped E85
      '95 80Q AEB VEMS E85
      • ChrisAudi80
        • Oct 2011
        • 236
        #33
        • prj
          • Mar 2010
          • 6308
          Instead of inventing the wheel just use stock ECU with prjmod.
          There is automatic gearbox on/off switch in the binary, which will allow you to use prjmod with autobox and all the comms will be taken care of by the ECU.
          Or just fit manual. Waste of time fitting standalone on automatic car.
          • ChrisAudi80
            • Oct 2011
            • 236
            #35
            Yes, you are correct.
            • Acki
              • Mar 2014
              • 302
              Why you edit your postings? There was no reason for?!
              • prj
                • Mar 2010
                • 6308
                Textbook example of what not to do on a forum.
