What kind of injector and FPR is used for the bigturbo_WMI file?
  • blackS2
    • Apr 2010
    • 455
    First - thanks a lot for sharing.
    Nice to see that I can continue my work on this ecu after getting stuck with fueling adresses years ago.
    There is one question.
    I can see
    1037cc @ 3.0bar FPR
    921cc @ 3.8 bar FPR
    898 cc @ 4.0 bar FPR
    so I would guess from this: f.e. a 921cc Injector (3bar) with a 3.8 bar RS2 FPR will match this bin (rough / besides latency)
    What kind of injector and FPR is used for the bigturbo_WMI file? I guess a Bosch type??
    best regards
    [__]=oooo=[__]
  • prj
    • Mar 2010
    • 6308
    Probably some Bosch EV14, but who cares?
    • blackS2
      • Apr 2010
      • 455
      just curious
      [__]=oooo=[__]
      • prj
        • Mar 2010
        • 6308
        Looks to me like 900CC at 4 bar, that said I wouldn't take it at face value...
        • blackS2
          • Apr 2010
          • 455
          Thanks... its just to prove my conclusions. I am comparing your two bins in WINOLS. I used the Bosch EV140280158040 980cc in my old S2 but I was never able to get OEM latency Data for them. So I was wondering about your injectors :-)
          [__]=oooo=[__]
          • blackS2
            • Apr 2010
            • 455
            ...by the way, there is a single difference between the two files at 07ff5 - the only I did not find in the XDF
            [__]=oooo=[__]
            • kymi
              • May 2014
              • 107
              0x7FF5 is in the code area that XDF will not cover. Quick look without idb, looks like the map switching. 0x88__ or 0xB8__
              • blackS2
                • Apr 2010
                • 455
                Ok
                I can see in OEM RS2 bin and in prj bin at 0x8800 there is code that refers to some tables.
                There are 3 differences between OEM and prj
                OEM refers to the three map linearization tables
                prj refers to new VE table, IAT correction Speed Density and a third new correction map at 0xA180 (rpm x load/6 x 6) that is not in XDF.
                This 0X8900 code is in prj mode on a second adress at 0XB800
                The differences between 0X8900 and 0XB800 is the reference to either first or second Ignition Table/Fuel Table.
                0X8900 and 0XB800 are identical in prj1 and prj2 (high boost) file.
                So I think both files support map switching.
                I dont get the difference at 07FF3
                [__]=oooo=[__]
                • prj
                  • Mar 2010
                  • 6308
                  I have to look... you must understand, I don't have one of these cars and haven't worked on this in a while.
                  I did it all from memory when putting it together - I am happy your cars start on this stuff
                  I still haven't uploaded my idb's, I will do so and probably it will clear stuff up.
                  Please don't think I am some kind of saint - I too make mistakes, also in the code, or can be some copy-paste mistake. Can also be completely irrelevant.
                  • blackS2
                    • Apr 2010
                    • 455
                    Thanks Dmitri - I appreciate that. I also moved on. I sold my S2. Bought a R8 V10 and doing MED Stuff on V10 now :-)
                    I also have to make up my mind with old Motronic because I did most S2 with aftermarked now.
                    But finally it makes me happy to discover the last 30% of missing infomation about the 2.3.2 after stuck at Stage 1 years ago :-)
                    But I will test this stuff on a S2 from a friend of mine - just for fun.
                    cheers
                    [__]=oooo=[__]
                    • Acki
                      • Mar 2014
                      • 302
                      Within a week? Nice.
                      • prj
                        • Mar 2010
                        • 6308
                        You mean reply speed?
                        I have a lot of work, it is normal I don't get to visit here all the time.
                        You have nothing to complain about - the service is as good as the price, and as the price is NONE, the service is also NONE
                          Well it seems you are here a lot at the moment anyway and this is good
                          • Acki
                            • Mar 2014
                            • 302
                            No. I’m not vwnuts.
                            I mean issue with tune a S2, sale the car and buy a R8 :-D
                            • blackS2
                              • Apr 2010
                              • 455
                              No. I’m not vwnuts.
                              Lol good one
                              Nope, my S2 was running perfect with VEMS. But after 13 years of S2 It was time for something new...
                              We did 970 HP on VEMS last Season. https://youtu.be/Am6GfXOVcgY
                              [__]=oooo=[__]
