I'm trying to get this working on my PC & car, so wanted to check a few things, as I've not been successful so far.
Firstly, are there any modifications required to the ECU? I've read through the site and I already have a different MAP sensor installed for the RS2 upgrade, which looks like that suggested.
I can't get anything to register on the dashboard now.
Cheers for any help.
- PC is windows 10
- I've got a 409.1 KKL interface, which I use with VCDS lite.
- This uses Windows 10 drivers for the chip and I've just this minute read the codes on the car (unfortunately, as the universally useless 00561 is back
- Downloaded the Tunerpro RT and completed the steps
- Downloaded Winlog 14.7 and got the dashboard loaded
- Added the M232 device using the dll supplied
- COM port set to COM4, as per the USB to COM port adapter's settings
