so as of lately im seeing 1-2 degrees pulled from cylinder 4 only when in boost. i have had problems with AAN chewing up rod bearings on 4 in the past but that was before i could see the per cylinder knock control. what i was wondering is if im seeing early indication of something failing on cylinder 4 or if i have a phantom knock issue?
i know PRJ said the stock knock control works perfect in 99% of applications PRJmod could be used on. i have not touched the knock control settings at all. i reduced timing from the mapping as low as 9 degrees advance and it did not show back up but thats far too low of a timing advance under boost to me. when i was knocking i timing was between 16-18 degrees advance. i did check and retorque my knock sensors to 12 ft/lbs as per the bentley manual specs but i figured if one was loose or over torqued it would trigger more than 1 cylinder. i have an oil pressure gauge in the car and i get 65-65psi on average driving under full boost at 26psi. those are the oil pressure numbers i have always seen since i installed the gauge over a year ago. i may end up pulling the pan and inspecting cylinder 4 rod and rod bearing for damage but im hoping to avoid that. engine runs perfectly fine under normal driving conditions. any thoughts on if this may be an indicator of some sort of rod failure or of 16-18 degrees timing with 26psi is just too much and only cylinder 4 is seeing the effects from it?
