On my desk it didn't crashes but I think it's cause the N75 etc. is deactivated cause of the missing knock sensors...
I think it's some task for a long winter.
Thanks so far!
Thanks so far!
| code:00000023 push Acc |
| code:000000XX muv A, Ram_73 - check if magic byte is set |
| code:000000XX jz Code_End |
| code:000000XX jbc SCON.0, Code_Next |
| code:000000XX clr SCON.1 code:000000XX pop Acc Code_Next |
| code:000000XX reti |
| code:000000XX clr IEN0.4 |
| Code_End code:000000XX pop Acc |
| code:00001B06 mov DPTR, #0x1FF0 | ||
| code:00001B09 clr A | ||
| code:00001B0A movc A, @A+DPTR OR
| code:00000000 clr SCON.0 Receiver interrupt |
| code:00000000 push B ; B-Register |
| code:00000000 clr C |
| code:00000000 mov A, RAM_7E |
| code:00000000 cjne A, 0xXX code_next -max number of transmitted bytes/var |
| Code_next |
| code:00000000 jc code_Continue |
| code:00000000 cjne A, 0xFF, Code_Code_clr_IEN0.4 jump to end of transmit |
| Code_Continue |
| code:00000000 inc RAM_7E |
| code:00000000 mov B, #2 ; B-Register |
| code:00000000 mul AB |
| code:00000000 pop B |
| code:00000000 pop PSW - is not needed |
| code:00000000 mov DPTR, #0x1XXX |
| code:00000000 jmp @A+DPTR |
code:00000000 sjmp code_byte_2 )) not 1 |
| end etc…. |
help.
copy paste from Dmitri's code
