Well, on the V8 the knock control is done by different chip and totally differently. One that does not use an external memory.
So I don't know - I can't tell you, I never reversed this.
On 2.3.2 the signal from the main processor is sent as-is to the knock processor and the knock processor simply sends it to the correct cylinder (solid state distributor) and introduces a delay into the signal when knock control requires it. This delay is logged with prjmod per cylinder to output knock data.
