The parameters of the launch control with stock turbo kkk7000.
  • #31
    Originally posted by Acki View Post
    I don't use the clutch switch (drive V8 automatic)
    Will mod my V8 file for ign cut during shifting
    thats very interesting! if you do that take some video, i'd like to see spark cut during shift on a V8 automatic.
    personally i dont feel that a fuel cut flat shift is a useful when compared to a spark cut flat shift. to me on turbo car the point of spark cut flat shift is so that the car backfires causing the turbo to keep spooled between shifts. on my car it never goes below 20psi when i use spark cut flat shift. the fuel cut would help with slightly faster shift by unloading the engine for a split second but it not nearly as useful as spark cut which unloads the engine plus keeps the turbo spooled up. i think this is why PRJ never made a fuel cut flat shift.
    "The really good drivers got the bugs on the side windows." Walter Röhrl
    • #32
      I want backfire during shifting, that's all :-D No other reason.
      • #33
        Launch control works with a bigturbo file. I just took it and set it up for stock.
        • #34
          Are you talking about Fuel cut LC or Spark cut LC?
          • #35
            Spark cut LC.
