Lucky to have the wizards help
carry on Matt, you have no fear!
ode:000019A0 This starts with the enabling or disabling of code:000019A0 the high speed logging via TPS. if the TPS code:000019A0 is pressed down above the value 0x0C it sets code:000019A0 Open_RAM to 0 disabling the logging. code:000019A0 code:000019A0 ; =============== S U B R O U T I N E ======================================= code:000019A0 code:000019A0 code:000019A0 Logging_Code_01: ; CODE XREF: IE0+C30↑p code:000019A0 20 18 1E jb RAM_23.0, code_19C1 ; Jump if Bit is set code:000019A3 75 D8 03 mov ADCON1, #3 ; Read TPS From AN3 code:000019A6 75 DA 00 mov DAPR, #0 ; D/A Converter Program Register code:000019A9 code:000019A9 code_19A9: ; CODE XREF: Logging_Code_01:code_19A9↓j code:000019A9 20 DC FD jb ADCON1.4, code_19A9 ; A/D Converter Control Register 1 code:000019AC E5 D9 mov A, ADDAT ; A/D Converter Data Register code:000019AE B4 C0 00 cjne A, #0xC0, code_19B1 ; Compare to TPS constant 90%. code:000019B1 code:000019B1 code_19B1: ; CODE XREF: Logging_Code_01+E↑j code:000019B1 50 07 jnc code_19BA ; Jump if Carry is clear code:000019B3 75 73 00 mov Open_RAM, #0 ; Move (Op1 <- Op2) code:000019B6 D2 18 setb RAM_23.0 ; Set Direct Bit code:000019B8 80 07 sjmp code_19C1 ; Short jump code:000019BA ; --------------------------------------------------------------------------- code:000019BA code:000019BA code_19BA: ; CODE XREF: Logging_Code_01:code_19B1↑j code:000019BA 75 73 01 mov Open_RAM, #1 ; Move (Op1 <- Op2) code:000019BD 75 F0 00 mov B, #0 ; B-Register code:000019C0 22 ret ; Return from subroutine code:000019C1 ; --------------------------------------------------------------------------- code:000019C1 code:000019C1 code_19C1: ; CODE XREF: Logging_Code_01↑j code:000019C1 ; Logging_Code_01+18↑j code:000019C1 E5 73 mov A, Open_RAM ; Move (Op1 <- Op2) code:000019C3 70 1B jnz code_19E0 ; Jump if Acc is not zero
