Hi, i cant make prjmod fast logging to work.
Engine is just running on Bigturbo file on ostrich emulator, with basic adjustment for different injectors.
Boost chip is some "stock type" chipped (not PRJmod), on eeprom.
Using audi 2x2 to OBD adapter, throught hex-can cable and full throttle switch i can connect throught VCDS.
I use KKL kables (have one with RL and also some older BL) and also tried BMW k+dcan.
Tried two laptops, both W7 32bit. Both used with mutliple another car diag and tuning. TunerproRT with ostrich emulator also.
Tunerpro ADX, loaded definition, then in preferences data-aq->interfacetypelugin->tunerprodataaq->choose com port for connected cable -> test, says ok and ready. Key on or engine running, click aquiredata connect , bottom yellow collumn go purple and say "DA:connecting". Nothing else happends.
Winlog. Loaded dash, open view-deviceconfiguration, there is to choose M2.3.2 fast log , config window popup . There is collumng COM, inside is "COM 1". I tried write it same "COM 4" for example or also just "4". Choosed all types of map sensor. No connection, no data stream.
What im doing wrong?
