On that basis I may not bother with the backs as it looks like time to take all the panels out. I can always change the front/rear bias from the head unit!
This of course is where I find that it's actually the rears that are more blown that the fronts... although they're all now showing their age. Maybe I should just listen to more soothing music instead.
Ck.
Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
What do I need to unscrew/remove/etc to get to the rear speakers? (Both the ones by the rear seats and the ones up behind.)
Cheers,
Ck.
Not quite as straightforward as I was hoping, but not impossible either.
Do you remember what size of speaker fits in the backs? The consensus is that 10cm (4 inch) fits the front nicely, but no size(s) have been suggested for the rears (yet)! I guess it's a 1 inch tweeter - not sure about the pair by the rear seats though.
Popped into one of my local car audio "specialists" earlier. They launched straight into the "you need 6x9's in the parcel shelf driven by a separate amplifier, and you might as well disconnect the standard rears, and we can do it for you for about £700". Yeah right.
Ck.
I am still running the standard rear speakers in mine but with the rest of the kit upgraded and provided you bias the sounds to the front it sounds great. ( I am running my front kenwood speakers and tweeters from my amp as well as a sub off the amp. I am very pleased with the set up and it gets some good comments too...)
So unless you have blown the rear speakers I would leave them be and bias the stereo towards the front. (you WILL need a sub though for bass)
Cheers,
Steve.
The Perfectionist
P.S. My front speakers are crossover with a high pass in the Amp at 100 - 120 Hz to improve sound quality. It really does help if you can use the small front speakers as mid range....
The Perfectionist
I use all my mids (51/4 and 61/2) in 125 range with a 12 slope down to around 100 hz.
The front speakers are now MB Quart RKC 110's (the ones which are effectively components where the tweeter sits on a bridge over the main cone).
I hadn't realised how bad the stock ones were getting!
Ck.
Its that time of the year again, time to upgrade ICE. I must point out Ive no idea on watt's volts or MHz's. All i know is you plug a speaker into the headunit or amp and it makes a lot of noise
Im trying to figure out how to upgrade the front speakers, and noticed there were two models recommended by the forum which are MB Quartz (DKC108 / 110). However, the famous ebay'er isnt selling them any more, and cant find any for sale in the UK ?! Have they been replaced by a newer model or something? cant find any place that sells them :/
I dont really want to spend more than £30 on the set, any others that can be recommeded?
ALSO, whats the best method of hooking these up? direct to the headunit or through the amp in the boot? and why. Also there has been talk of crossovers (no idea what they are, jamo explained it to me once but it confused me more (dosnt take much)), do I need them?
I found some cheap 4" in haulfrauds Linky which would be the easy option as I can fit them today!! But no idea if they are any good?!
Any help is appreciated, I'd love to find the MB Quartz option!
Plug and play... (Will sound best crossed over and through an amp...)
To connect to the amp you need to run the cable (obviously) then you should (if your amp is decent have at least a HP (high pass) and LP (low pass) filter on the seperate channels. You need to choose High pass as this will only allow the upper frequency range to be sent to your front speakers. They will then no "Fart" when trying to play low frequencies that they are not good at...
Take a photo of the settings on your amp and we can help!
Cheers,
Steve
The Perfectionist
