Replacement speakers: what do people recommend?
  • Graham
    • 1622
    #61
    Originally posted by Greg_S
    Hi Greg, can you remember if the plate in the picture was used for anything else, i.e. was it holding anything else.
    What were the studs mounted to? are they part of the grill? if so i can just remove that plate and make a new plate which will house the nutserts and speaker
      • 12431
      Graham
      As far as I could see it was just for the speaker, but i didnt remove the sound deading to check further up since I suspect it may also be a mount for the carbon trims in the rear panels.
      I would have thought the plate can be removed a new one fabricated to suit though.
      HTH
      • Graham
        • 1622
        #63
        Cool, i have bid on some MB Quart 6.5" speakers Model PCE-216 6.5" Component Set, 9 hrs to go, then once theyre here i'll start the how too guide.
        Cheers for your help.
        Graham
        • johne
          • Apr 2007
          • 1406
          Originally posted by HPmuirt
          Hey John,
          7. I have 4" MQ Quarts in the front. Can anyone recommend a suitable bass blocker/passive crossover/capacitor which will knock some of the bass off?
          Cheers n
          Si
          In answer to 7, I should have said 100uf NOT 10 uf! 10 uf would cut the bass too much.
          Available from RS Components part number 521-1621. Minimum quantity is 5 but they're only 32p each. Maplin part number VM76H but 98p each.
          You need to wire it in series with the speaker, not across the speaker terminals as suggested by someone else in another post.
          John
          • johne
            • Apr 2007
            • 1406
            Graham, the studs are mounted to the speaker grill. You can just remove the plate and make a new one, the plate isn't used for anything else.
            • Graham
              • 1622
              #66
              Item won, i have got a set of MB quart 6.5" components on the way. Will take pictures when i install them and do a how too.
              Thanks people
              Graham
