Hi. My radio reception is practically non exisitant so trying to get to the bottom of it!! Trying to trace the usual culprit of the power lead to the bee sting amplifier at the ISO end. At the ariel end its a black wire.
At some stage the original ISO block has been cut off leaving:
Red/Blue - 12v
Brown - earth
grey / blue - illumination?
white / blue - no idea
white - door open buzzer
So when I tried connecting the white lead, which I thought was the amp feed, to the 12v out the amp head and it just sets off the door open buzzer - heard of this before! Put 12v to the other white / blue lead and it has no effect at all and certainly doesnt make any difference to the radio
Anyone know what this lead is? Nor the white/blue lead. Its entirely possible the amplifier is borked but Im not sure if Ive found the right lead to test it with yet so feeling a bit stumped!
cheers
Paul
Red/Blue - 12v
Brown - earth
Anyone know what this lead is? Nor the white/blue lead. Its entirely possible the amplifier is borked but Im not sure if Ive found the right lead to test it with yet so feeling a bit stumped! cheers
Paul
Had a look at the diagrams on Mike's site and it doesnt look the same, so tis well odd.
Sure there's a pic in someones post of the ISO plug & wiring in an S2, be useful to compare, have to dig the thread out. Its had at least two different cd changer instals and a pretty professional tho quite old phone set up at some time, by the looks of what remains under the back seat - also bits of broken window / screen glass which is a bit worrying!
Not sure if the one thats on is OEM - has a sliver band around the base which doesnt look standard to me. Will check up on those inline boosters - seen em on ebay also - looks a good solution and will elimate the "missing" white lead!
