Aerial Amplifier
  • Aerial Amplifier
    Can anyone tell me if this could be fitted to an S2 so that I could actually listen to the radio?
    ex '93 Avant owner
    I think that this is for the glass type aerials and not for a bee sting antenna. I cant tell without seeing it better.
    David
      Yup, thats the new A4 Avant aerial amplifier for glass rear window aerial. No reason why you couldn't fit it. You may have a little bit of fun with the leads etc, but no reason why not!
      Martyn
      Martyn
      www.vagparts.com
        Afaik S2's have an aerial amplifier stock installed?
        Red cars are the fastest ones...
        - Team Irry -
          Yeah, but mine doesn't work for some reason. I get crap reception on all radio stations unless I'm parked next to the transmitter!
          ex '93 Avant owner
            Mine's the same, always seems to be something else to fix first. Didn't I read somewhere that you can fit a unit from a Vauxhall at about 1/2 the price?
            Still haven't fixed my courtesy light switch
              You said it! I've got a boost leak, half my electrics don't work, my ABS doesn't work, I need new front tyres etc etc etc
              But I'll try and fix my radio!
              ex '93 Avant owner
                Yeah im sure the ones off the corsa or something like that fit.
                The aerial base which has the amplifier in regularily overheat etc and break.
                have you tried GSF?
                  maybe a stupid questinon but, you have connected the aerial amp remote to the headunit, ringt?
                  Or I might just be lucky with my old '91s, almost too good reception!
                  - Team Irry -
                    Yeah it has to be connected to the power aerial lead. Blue normally i think
                      I have the same problem and AvantS2 quoted
                      "The Vauxhall part number is 90389799 which costs £18.66 + VAT. The roof mounting is the same. You will just need to put a different terminal on to match the Audi one. Should save you about £40"
                      I haven't changed it yet but I really should get the finger out !
                      cheers
                      Raymond
                      1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
                      1987 CQ85RS
                      1994 S2 Avant- Gone
                      1991 V8 -Gone, but lives on in the TDi and CQ
                      Fintray Hillclimb - 33.20s
                      Doune Hillclimb - 55.02s
                      Forrestburn Hillclimb - 52.61
