I'm currently backdating the aftermarket HU in my RS2 to the Gamma CC. I know the gamma has a builtin 2x20 amp for the front speakers and utilizes line outs for the rear speakers with built in amps. The wiring diagram on the gamma shows that there are also line outs for the front speakers which are separate from the pins used for the direct connection to the front speakers. My question is can you use a 4 channel amp and a custom RCA plug tied in to the 4 line outs and the common ground in the gamma to power both front and rear speakers through the amp?
All my speakers are currently tied into my amp so I'd like to be able to just plug the gamma into the RCA plugs that are already there.
