Originally posted by horvathg
Front and rear speakers
Beetie,Originally posted by BeetieDo you think the dash will be difficult to cut? Or would it just be easier to find some speakers that would require no cutting...
the das job would require some skills because the windshield is quite close to the speaker hole. Apart from that the ears of the model shown on ebay should be removed, too. A round shaped speaker would fit more easily. Working inside the speaker hole is quite a sheete arbeit because you don't see the tip of you cutter tool. You have to watch it from outside the glass...
Gabor
96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAFComment
Hi Jamo, Just want to pick your brain. I've got the DKC 108's upfront and would like to upgrade the original rears. I take it they are 5 1/4". What do you recommend? can I go to the 6"? I'm looking at the focals at the moment. Is it an easy swap or is it like the Cabrio and the speakers are built into a silly subframe thing.All ideas are appreciated.Originally posted by JamoMB Quarts DKC 108, you can buy the newer DKD or DKE 108 MB Quarts which cost a bit more, only major difference is they DKE go to 75Hz in Bass and the DKC go to 90 Hz but as i;ve set my DSP to 100 Hz for the dash speakers this is not a problem.
MarkMark
Race Clio RS197
S2 Coupe ABY (Green) - RIP
S2 Coupe ABY (Blue) - SoldComment
Hi just wondered where you got your MB Quart DKC 108's and how much they were, i just missed some for £25 on e-bay and all they have listed now is an american supplier who wants lots to ship over to uk???Originally posted by rotoryboyHi Jamo, Just want to pick your brain. I've got the DKC 108's upfront and would like to upgrade the original rears. I take it they are 5 1/4". What do you recommend? can I go to the 6"? I'm looking at the focals at the moment. Is it an easy swap or is it like the Cabrio and the speakers are built into a silly subframe thing.All ideas are appreciated.
Mark
Cheers.'94 ABYComment
Mark
I don't know the answer to that one, but FatAudi80 should be your man.
Theres another person, forum name escapes me, Mike i believe, i'll look it up.
I have 6x9 in my rear side quarters as that is what my car came with so i dont know what will fit standard.
If you want to push a little more through your fronts (i use my dkc108 as tweeters basically) then try the JBL 4" speakers. They sound good, and i have a brand new pair as backup.Comment
Hi mate, I payed a fortune for them on ebay. Brand new £10.50 ha bargain.Originally posted by bob69Hi just wondered where you got your MB Quart DKC 108's and how much they were, i just missed some for £25 on e-bay and all they have listed now is an american supplier who wants lots to ship over to uk???
Cheers.Mark
Race Clio RS197
