:mischeif:
Ive come up with a couple of ways, the coolest being with automatic A/B switches, but the easiest is to hot-plug the wires running to the speakers from the boot, same with the wires from the amp, and wires that could be run from the headunit to the boot.
That way you could just unplug the amp and connect the headunit amp's in the boot. Obviously you want to be using very high quality connectors.
as well...
Im inclined to think you might be right though. I was thinking that the dual sub's would provide tighter response rather than massively increased volume
Dual Voice Coil - http://www.crutchfield.com/S-DkaDjDv...fers_dual.html
as well...
