Graduated Audio Level Adjustment
  • Paulm
    • Dec 2003
    • 489
    I bought a new Blaupunkt stereo that has sound level adjustment. Basically the faster you go the louder the stereo gets. I thought it came all in one but no. I need a GALA sensor, where can i but such a thing.
    Kind of been had i think. I only bought the stereo as it had this feature
    cheers
    Paul
    S4 2.7 Twin Turbo, with a few mods
  • s2avant
    • 2426
    You should be able to pick up a GALA signal from the dash insert or ECU. I'll have to dig out my wiring diagrams to find which wire it is.
    Ben
    I've only just realised what GALA stands for
      Originally posted by s2avant
      Ben
      And?
      (edit)
      Doh, just read the title again
      • s2avant
        • 2426
        Exactly what I did
        At least I'm not the only one.
        Ben
        • Paulm
          • Dec 2003
          • 489
          I had no idea what it stood for either, i found it on the net when doing a search for GALA. I think the newer Audis have this as standard.
          Ben,
          so you saying my car has one of these, just need to find the wire?
          Paul
          • s2avant
            • 2426
            IIRC the Audi 80 passes speed signals between the ECU and dash insert and also has an output for the head unit.
            I don't know if the wire is there or if you need to run one form the dash insert.
            Ben
            • Paulm
              • Dec 2003
              • 489
              I don't know what you mean by the dash insert. If you could find the wiring diagram that would be very helpful. As i am kind of lost here.
              Paul
              • dkw_dude
                • 555
                • Country: Norway
                cheers
                Paul
                Have done this on my -91 3B a while ago, not totally sure but i think the signal is from a blue and red wire in the ISO connector which also has +12V and ground. From my memory I measured ~9V on this w. ignition on.
                Works very nice when hooked up
                Leif-Helge
                -91 S2 VEMS and Comp Turbo
                -12 B** 530XD Touring "S2 parts transporter, and daily driver"
                • s2avant
                  • 2426
                  Paul,
                  Sorry mate. The dash insert is the clocks (rev counter, speedo etc). It's me being a parts geek again and expecting people to know what I mean
                  dkw_dude is right. I remember having a spare connector behind my head unit. Can't remember the colour of it but it must have been the GALA wire.
                  Ben
                  • Paulm
                    • Dec 2003
                    • 489
                    cheers lads will have a look tomorrow
                    Paul
                    • Paulm
                      • Dec 2003
                      • 489
                      ok looked at this today.
                      The spare wire for the stereo puts out .115 volts and climbs slowly to .118 then to .12volts at around 100mph. my stereo does nothing.
                      What sort of output should this GALA do, should i see more voltage fluctuation or what
                      cheers
                      Paul
                      • audiman
                        • 4827
                        Voltage should change more than this, would expect you are on the wrong wire. Not sure which wire it is tho? sorry. Come on Ben, get that wiring diagram out. If there is no luck by this weekend, someone is bound to have a diagram with them to look at Paul.
                        Tom C - www.rcmr.co.uk
                        Audi UR Quattro
                        Audi 100 C3 2.0 5 cyl 115ps
                        Audi B5 RS4 645ps 911nm
                        • s2avant
                          • 2426
                          I've been a tad busy these last couple of days with my oil issues. You'd be proud of the bodging in my engine bay now Tom.
                          I'll try and remember to bring the current flow diagrams to Billing with me.
                          Ben
                          • Paulm
                            • Dec 2003
                            • 489
                            I won't be @ Billing as it far to far for me, I am 50 miles north of Aberdeen. + my car will be in bits this weekend as I never fitted the turbo last Friday so will start it today.
                            Tom, Ben. if 1 of you guys were able to look over the diagrams and give me a rough idea of where and what i am looking for it would be very much appreciated.
                            cheers
                            Paul
                            • dkw_dude
                              • 555
                              • Country: Norway
                              A picture of the wiring on my Blaupunkt Toronto, red arrow points to where I connected the speed signal from the car, on my -91- S2 3B a white/blue wire as seen on the pic.
                              More info here
                              read explanation about the ** marked pin.
                              Leif-Helge
