The ICE wiring in my RS2 has still got the original ISO connectors. I'm not used to this luxury as the wiring has normally been butchered.
The connector for live feed, etc only has 4 wires, i.e. permanent live, ground, illumination & antenna amp. The problem is that in it's current position the live feed pin only goes to the ignition feed on the Blaupunkt connector (pin 7). So it needs another wire to match up to the live feed on the Blaupunkt radio (pin 4).
How have people got around this with their Blaupunkt units ? Is there an adapter cable available or is it possible to just fit another wire in pin 4 of the car connector & splice it into the ignition wire ? I have tried doing this but the wire terminals I've taken out of donor ISO connectors have been too big. I don't really want to resort to chopping off the ISO connector if I don't have to....
