How to get AUX-in on Blaupunkt?
  • AudiRS
    • Jul 2006
    • 159
    • Country: Norway
    After mye Blaupunkt Bremen Mp76 where nicked, I bought my self a Blaupunkt Rome Europe Nav56e.
    I`m trying to get Aux-in to work on this headunit, but can`t get it to work.
    On rear of the headunit there is a port for mini-ISO with Aux, so i bought a adapter to fit this mini-ISO whit AUX-in-output.
    The problem is that I can`t get an AUX-in-symbol at the player = No sound.
    Anyone got some hot tips about getting aux-in on this player?
    Does`nt this player support AUX-in even if it got a output for it?
    Is it something I have to do in order to get sound from an auxilary soundsource?
    Is there a way to change the order of the pins in the mini-ISO so i can get the sound up and running at the car-audio system?
    (Now the pins on the adapter goes to AF-R, AF-L and AF (earth).
    Help please?
    - `95 Audi S2 B4 2,2T Avant
    - `07 Audi A6 C6 S-line Lim.
    - `96 Audi A6 C4 2,5TDIs Quattro
    - `93 Audi 80 TDI Avant
    - `89 Audi Coupe 2,3E 20v quattro[/URL]
    - `99 Audi A4 B5 1,8TS 20v quattro
    - `92 Audi 80 B4 2,3E 10v quattro
  • s2driveruk
    • 12696
    on my ancient Blau Alicante, it was a menu option to turn on the Aux function, maybe yours is the same...
    1992 3b S2 Coupe
    • s2driveruk
      • 12696
      see here:
      1992 3b S2 Coupe
      • Jonas_R
        • 3781
        • Country: Denmark
        What are you trying to connect to the radio? If you look on top of the radio you can see what each mini iso is for.
        I'm using the same radio in my Suzuki Swift, and from memory on mini iso plugs is for steering controls, one is for cd-changer/Ipod interface and one is line out for amplifier.
        Anyhow to change to the cd-changer you just have to press source "SRC".
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • AudiRS
          • Jul 2006
          • 159
          • Country: Norway
          Are you using the Blaupunkt Rome with Aux in?
          The wiring-schematics is now uploaded as a picture in the first post.
          When I hit "SRC/source", I only got "no CD found".
          • borderS2
            • Jul 2008
            • 166
            Manual Here
            Don't see any reference to Aux in.
            S2 91 (red standard)
            • AudiRS
              • Jul 2006
              • 159
              • Country: Norway
              Weird if this newer head-unit don`t have AUX-in as a feature right?
              I`ve looked in the Menu-section without any luck
              The player I`ve got now is the Blaupunkt Rome Europe Nav56e.
              • AudiRS
                • Jul 2006
                • 159
                • Country: Norway
                Originally posted by borderS2
                A thanks. But why is there a mini-iso and a adapter to get, that fit for Aux-In if this is`nt an option?
                • s2driveruk
                  • 12696
                  drop me an IM with your email, found the manual...
                  1992 3b S2 Coupe
                  • AudiRS
                    • Jul 2006
                    • 159
                    • Country: Norway
                    Thanks, but BorderS2 already found a link to the original manual.
                    But no help there how to get the Blaupunkt Rome to play music from an auxilary source...
                    • s2driveruk
                      • 12696
                      np
                      1992 3b S2 Coupe
                      • Jonas_R
                        • 3781
                        • Country: Denmark
                        On the label of your radio it says changer and not AUX In, so I dont think it has AUX IN. I have just been down in my car and I can't find anywhere in the menu's where I can change it to AUX.
                        Again what are you trying to connect?
                        • AudiRS
                          • Jul 2006
                          • 159
                          • Country: Norway
                          I`m trying to connect Aux-In
                          Where does the CD-changer goes in? left, middle og right mini-iso?
                          • Jonas_R
                            • 3781
                            • Country: Denmark
                            The CD-Changer goes in to plug that says "Changer" on the label
                            I get that you are trying to connect AUX In, but is it an Ipod your trying to hook up or what?
                            But I have the same Radio and I as I just said I can't find anything in the menu system on the radio refering to AUX In.
                            • AudiRS
                              • Jul 2006
                              • 159
                              • Country: Norway
                              Ah, my mistace. I was trying with my LG Optiums One phone as an Aux-source.
                              This adapter I`ve bought goes in at the same place where the changer goes.
                              When you`ve got an changer, is there only a sound-signal you get from this? It that case it should work with Aux-in also..i think
