Hi, I will put some pictures up later but I thought I would give you an update.
So Far I have fitted some MB Quart Components in the front speaker locations, with the tweeters a direct fit in the demister vents.... What a difference !
they are not even run in yet and they sound superb.
I am Running a Sony Minidisc head unit, and an Alpine Amp for the front Components. With a Kenwood Mono Amp for the Sub in the boot.
The sub choice is currently between my trusty old Alpine 10" in a Total overkill 1" thick MDF sealed enclosure of about 0.5cu/ft and loads of wadding, which looks terrible and battered, but still kicks like a mule and sounds superb..... OR the new Infinity perfect 12.1 in a generic flimsy box of indeterminate volume, which drops lower but has nowhere near the kick or sound of the Alpine.
Now I`m sure a lot of this is to do with the Crap Box design and I`m hoping my New Fibreglassed boot corner enclosure will fix that, but I am still undecided whether to mount the 12 in there or the Alpine Ten, and sell on the Infinity ?
I dont want to lose the Punch of the 10 so was going to keep the enclosure small, that way it will be a small volume for the 12" but a Slightly bigger than now volume for the 10" which should allow the 10 to drop lower or th e12 to hit harder ?
IF that makes any sense ?
I have also fitted Infinity Reference 6.5" in the modified stock rear "Shelf" (90Q Remember) positions, which just gives rear fill, run from the Head unit internal amp.
I`ll get some pictures of the Fibreglassing and components later.
In the mean time if you want a set of the same, the chap I bought mine off has another set on Ebay at the moment:
MB Quarts
No connection other than a happy customer, and thought someone here might benefit
Dom
they are not even run in yet and they sound superb.I am Running a Sony Minidisc head unit, and an Alpine Amp for the front Components. With a Kenwood Mono Amp for the Sub in the boot.
MB Quarts
Dom
