A better test is to connect any working speaker to the rear connection point to verify audio signal is getting there… and if not then check at rear speaker cables where they attach to gamma unit.
Surely a multimeter test across positive and negative terminals will confirm continuity and therefore remove the speakers from the equation...speaker failure is unlikely... shorting out the speaker termimals will usually result in damage to the amp...
Axtive speakers do not work with an amplifier, as the active speakers have a built in amplifier...if you are combining the two systems then you will encounter serious problems.
