The making of a 1DIN Car PC - design opinions?
  • Jonas_R
    • 3781
    • Country: Denmark
    So i'm starting to make myself a 1DIN car pc.
    First I found this 1DIN radio with a flip out holder for a tablet Eonon M1003:
    Video:
    Plan was to use this combined with a dell venue 8 pro that I had and then connect that to a usb hub and have vagcom and zeitronix connected at all times.
    However nothing never goes as planned, thought the radio looked a bit ugly to be honest and it sticks out alot.
    So decided to do something else instead.
    I bought myself a Pipo X8 from ebay.de which will be arriving next week.
    I will gut the Pipo X8 and use it for parts:
    So I have to ideas and would like people's input to which one I should go for:
    Touch screen mod:
    I will remove the plastic tablet holder which will leave a steel plate where I can secure the touch screen. I will have to cut aprroximately 20mm of the steel plate which is ok because then the screen will sit inside the radio and not stick out.
    Option 1:
    • Only use the amplifier, aux input and motor control for the holder from the radio and scrap the rest
    • Mount the small mainboard of the Pipo X8 inside the radio
    • Make a clean new front for the radio with usb, aux, sd card and power buttin in the front.
    • The front will have a small latch that will open like a cd-drive when the screen pops out.
    Upsides:
    Clean look and fairly easy to do.
    More space inside for flex cables and boards etc.
    Downsides
    No FM radio - This can be bought from cartft or similar.
    Option 2A:
    • Reuse the whole radio
    • Make new frame around the radio front panel with a latch that opens like a cd-drive (I will keep the current display etc.)
    • Mount mainboard inside
    Upsides:
    FM Radio, USB and SD access so no need to turn the pc on to listen to music
    Relative easy to make new frame around radio with latch.
    Downsides:
    Radio front panel will still stick out
    Not that much room to fit flex cables and mainboard.
    Option 2B:
    • Make new clean front and dont use original radio front panel = I will have to make room in the new front for buttons, display etc.
    Upsides:
    Clean front and the radio panel does not stick out.
    Downsides:
    Much more difficult to make a new front radio panel.
    I will update the thread as I progress with the build.
    I'm leaning towards option 1 to be honest, not sure I really need the FM radio that much.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Henkjan
    • 1705
    my thoughts also. and you can use yr phone hooked up to aux (or BT) if you need radio
    • Jonas_R
      • 3781
      • Country: Denmark
      Yeah that is true good point, could also just setup up a hotspot with my phone and use a app to stream it.
      • diesel des
        • 3896
        Interesting setups. Will be good to see what a finished setup looks like.
        • Jonas_R
          • 3781
          • Country: Denmark
          So had some time today and got the plastic holder off.
          Looks like a nice backplate for mounting the touch screen.
          • bhlegit
            • Sep 2018
            • 114
            how did this go? interested in doing the same..
            ABY
