A8 D2 speakers in audi rs2 avant
  • Jiri
    • Dec 2011
    • 254
    • Country: Belgium
    Hello guys,
    When i buyed the car there were Bostons in de rear doors. I wanna keep it to an original look but a clear Sound. Anyone has the original speakers dimensions?
    I thought to Put A8 D2 böse speakers.
  • HPsauce
    • Sep 2015
    • 227
    Be very wary of D2 A8 Bose speakers as they have a very low impedance.
    The correct Bose amp and speakers work fine together but don't usually mix and match with anything else.
    • Jiri
      • Dec 2011
      • 254
      • Country: Belgium
      So what are you proposing to change to?
      • HPsauce
        • Sep 2015
        • 227
        Eh? I'm not changing anything.
        • Henkjan
          • 1705
          The A8 Bose rear speakers are rather simple 10cm full range, nothing to applaud about.
          If you want an upgrade, buy decent speakers (e.g. Focal) and a proper amp and keep/get the original grills to keep the stock look
          • HPsauce
            • Sep 2015
            • 227
            Well my D2 S8 with Bose had rather more than that at the rear.......
            Wide-range speakers in each rear door and bass in the parcel shelf. You do need the full set (including the fronts too) to work properly of course.
            • Henkjan
              • 1705
              the bass in the parcel shelf is a sort of sub for the entire system, not specific for the rear door set.
              The front is prety OK (for a factory set), but you can do much better with aftermarket gear.
              While the Bose did give a better sq than the normal ICE in the A8, it is still far away from what the current B&O has to offer, and I see no reason why you would want to go through the trouble of fitting it in aan S2.
              • Jiri
                • Dec 2011
                • 254
                • Country: Belgium
                Thanks guys,
                Were the speaker panels not 1 with the speaker?
                So focal, would be a solution,which type do you recommand?
                • M_GORDON
                  • Oct 2008
                  • 1295
                  • Home: Isle of Man Current: Vatican City State
                  The 80's rear doors have 13cm speakers with own grille, a separated tweeter and a little ampli.
                  Good sound but a little poor for me.
                  photobucket SUCKS
                  • Jiri
                    • Dec 2011
                    • 254
                    • Country: Belgium
                    So i must looking for a speaker that has 13 cm, does audi has one? Except the original nokia.
                    • Henkjan
                      • 1705
                      if you want to keep the stock looks, put a 10cm coaxial in the front, will fit behind the ori grills. or do as I did and put a compo set with the tweeters in little pods on the dash (no holes needed), woofs in the ori location. (see pic)
                      for the rear: personally I use rear speakers only as "rear-fill", so only midrange. but if you like to also have the full sound in the back seats, a composet with a 13cm woofer will do nicely
                      there was a GB for Focal speakers a while a go, some discussion on what fits where is also in that thread: http://www.s2forum.com/forum/showthr...ighlight=focal
