Strange Rattle on Acceleration
  • Knight Rider S4
    • 3541
    I have this really annoying noise coming from the passenger side front when pulling off in 1st thengoing to 2nd and 3rd accelerating hardish it is like rrrrrrrrrrrr then change gear then the same again so on, have checked the exhaust for lose clamps ,guards so on but nothing really showing up as lose or hitting anything ,the car had been sitting for about 3 weeks then the noise appeared, so i am wondering can be the cat gone or is something to do with the transmission or driveshafts ???
    Any ideas??
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
  • Martynf
    • 1885
    Bet yer its the heat shielding rotton on the bottom bend of the downpipes. before the cats. It rots and get loose then rattles. Mine did this, drove me loony tunes until I figured it!! 30 seconds with tin snips sorts it for no charge!! ;-)
    Hope this is the cause for you.
    Martyn
    www.vagparts.com
      Cats make a 'purrrrrr' sound - I think the 'rrrrrrrr' sound must be the heatshield like Martyn says.
      Sorry !
        If you fit a bigger turbo you can get a 'grrrrrr' sound if you like
        Really sorry..........
        • Martynf
          • 1885
          :d :d
          Martyn
          www.vagparts.com
          • Knight Rider S4
            • 3541
            Just away to check the heat sheild with my tin snips
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • SimonS4MTM
              • 63
              What year S4 do you have, Audi 100 type??
              Simon S4 MTM 320bhp, Milltek, Mov-it, H&R, Short shifter.
              www.f1systems.com
              • Ski
                • 2591
                knight-riders come with a very inteligent fault diagnotics.. just ask your onboard computer.
                My money is on the heatshield.
                ABY Coupe
                • Knight Rider S4
                  • 3541
                  Right nothing there needing cut but found that one of the brackets under the bumper that holds the inter-cooler has snapped and there seems to be a lot of movement there, so have to source mounting for somewhere and see if that cures the problem
                  And yes the model is 100 S4 1993
                  Were could i found the mounting for this ,has anybody here fitted bigger intercooler and still got the orignal housing brackets ??
                  93 S2 Avant Parting
                  91 URQ RR
                  02 A4 tdi Avant
